Lately I keep running into these problems, so here they are:
- Can you define export order somewhere? Like layer up or down in Archicad or some other way?
From what I've seen this is mostly needed with annotations, where 2 annotations on top of each other the outcome is kinda random.
I want to see this:
And here it goes wrong (sometimes):
- Is it possible to edit the size, color etc. and the location of text? These might be different things.
I looked into the css and markers but couldn't find the right code to edit. Only to change size, color etc. of all text, but that isn't what I want.
1 is just normal text annotation, 2 is a dimension with a text annotation beneath it (If I can edit the text of this dimension, it might be possible to automate this) and 3 is a different dimension.
So if I want to edit size, color etc. of only 2, how to do it? Also: BBIM determines the location of dimensions by itself, but as you can see this goes wrong sometimes. Is it possible to change location per dimension text manually?
How to change font style of 1 line in a text annotation?
It isn't possible to press enter in these lines, you have to add a new one. Feature or bug?
You can only choose font size for the whole box, not per line and also not eg. bold or italics.
I imagine the solution for now would be to add 2 boxes to every literal, where the first one would be size and second one style.
If you're able to enter in the literal, then this would be an easy way to make text annotations!
I did it in this SpaceTag by coding it into the symbol.svg, but that's only possible because all space tags are the same for now.
I hope someone knows more and maybe this helped somebody ;)
Thanks!!
