BBIM not loading certain elements
  1. L
    Hi there!!
    I've been experimenting some issues when importing an IFC from Tekla Structures.
    BBIM doesn't seem to import all the elements in the IFC.
    I include two screenshots of the same model, loaded into BBIM and BIM Collab Zoom.
    Any clues on what's happening and how can I fix it?
    Thanks in advance!!!
  2. G
    I think the ifc schema gurus need to access the contents of the ifc file to see why the elements don't load. Are you allowed to share it, or maybe share a stripped down version with only some elements that don't load ?
  3. A
    @leGordeau
    What BBIM version you're using?
    To fix those kind of errors we indeed will need some .ifc example to reproduce the issue.
  4. L
    Thank you both for your replies.
    I'm figuring out how to extract a portion of the IFC file to share with you.
    As soon as I manage to do that, I'll post it here.
    Thank you!!
  5. C
    Buenas,
    Even before sharing the file, you may identify where the problem lies by validating it with IfcOpenShell, which can be done from inside BlenderBIM as follows:
    You'll need to have started Blender from a console, in which the validation results will be printed.
  6. L
    Thanks for the advice, @cvillagrasa
    I'll do that test to see if that gives any clues.
    Saludos!
