Hi guys,
i tried to excute a simple clash detection but i get this error:
I tested the tool with 2 different computers (windows os).
Am i doing something wrong?
Hi guys,
BCF results are not yet available. Export using a .json extension instead.
It works.
Thank you.
Hi guys, is bcf exporting during a clash not implemented yet? How can I use the json format?
Luckly i spotted this that could be a temporary workaround: https://www.linkedin.com/posts/chuncahk_finally-have-some-time-to-play-around-the-activity-7242377809778671617-p7i7?utm_source=share&utm_medium=member_desktop and in the comment found the solution.
Everytingh is here: https://github.com/IfcOpenShell/IfcOpenShell/issues/5377
I changed the clash"position" text for clash"p1" in the line 162 of ifcclash.py and when i click "Execute IFC Clash" I save as .bcf
kudos to @willformigoni
Fixed after this commit
