by bernd on 17 Apr 2024, edited 18 Apr 2024
Assumed I have a BIM-Modell:
if I have a picture. What would be needed to create the same camera position from the BIM-Modell
I assume: the viewpoint and the focal length
Is it possible with this to create a similar picture from the BIM-Modell
I am aware of the linies in the picture would be needed to be strechted
Thus I write similar and not identical.
Furthermore if I woul do the same with a video of a drone flight and the BIM-Modell.
Are there any reads to know about such workflows ... I do not need a renderend picture or video. I am fine the way it is like in the ifc. I am only interested in camera position and camera flight in the modell the same way as drone flight video.
cheers bernd
by brunopostle on 17 Apr 2024
This can be done in blender, though I have never tried myself. Search for 'matchmoving' and/or 'camera tracking'.
R
by RaphaëlVouilloz on 17 Apr 2024, edited 17 Apr 2024
+3 votes
If you have multiple images from drone flight, you could run a photogrammetry? From Meshroom you can get an .abc through the StructureFromMotion node, when imported into Blender you have all the positions converted to Blender cameras.
With just one image, I would draw the perspective on the Freecad sketcher, but that's more manual. EPFL students do it with paintings. Not sure if it works with a photo.
G
by Gorgious on 18 Apr 2024
+4 votes
Fspy is the goto foss if you want to recreate a 3D perspective viewpoint from a photo.
https://fspy.io/
It used to be a Blender addon but it's now standalone, although there is a an addon to import fspy projects into Blender.
Basically you import your image, draw perspective lines, input a length and it outputs camera data (position, rotation, focal length).
If you have a video input you can use the camera tracking workflow inside Blender although I've never used it and it seems there are better alternatives. I don't know them.
Cheers
by stefanm2 on 18 Apr 2024
Hi bernd, don't believe the metadatas of the (drone)picture... for tracking the flight I suggest motion/cameratracking (possible) with blender, there are some vids on yt.
