Hi @stephen_l,
Is it possible to have this read in fractions.
That is, go from 1.2187' to 1' - 2 5/8"?
Perhaps there's a preference where you can set the tolerance it measures by, like by 1/32, or 1/16, 1/8, etc,
Hi @stephen_l,
Unit conversion to strings rely on blender's api (bpy.utils.units.to_string) and depends on "separate units" in scene units configuration. Unfortunately as far as i know, support for fractions is not implemented.
Any known robust available algo ?
Haha... :)
not sure how useful it would be.
https://chatgpt.com/share/0897babd-6b9f-48fd-9a98-ce11bc1f1de1
Wow, we are in another world.
from fractions import Fraction
def decimal_to_feet_inches(decimal_feet, tolerance=16):
Convert a decimal feet measurement to feet and inches with a specified fraction tolerance.
:param decimal_feet: Measurement in decimal feet.
:param tolerance: Fraction tolerance (denominator), e.g., 32, 16, 8, etc.
:return: A string representation of the measurement in feet and inches.
decimal_feet = decimal_feet * 3.28084
feet = int(decimal_feet)
remaining_decimal_feet = decimal_feet - feet
total_inches = remaining_decimal_feet * 12
inches = int(total_inches)
remaining_decimal_inches = total_inches - inches
fraction = Fraction(round(remaining_decimal_inches * tolerance), tolerance)
# Adjust the fraction
if fraction.denominator > tolerance:
fraction = Fraction(round(remaining_decimal_inches * tolerance))
# If fraction is 0, we just return feet and inches
if fraction == 0:
return f"{feet}' - {inches}\""
else:
# If the fraction is exactly 1, we just return feet and inches plus 1
if fraction == 1:
inches += 1
readout = f"{feet}' - {inches}\""
else:
readout = f"{feet}' - {inches} {fraction}\""
return readout
def _translation(self, trs: TransformAction) -> Matrix:
"""Evaluate translation
:param trs: TransformAction
:return: Transform matrix
# By default, trs.space is active object's matrix_world normalized
about = trs.space
about.translation[:] = trs.snap_from
# snap_to in trs.space
delta = Geom3d.matrix_inverted(about) @ Constraint.apply(trs, trs.snap_to, about)
delta_len = delta.length
if trs.has(TransformType.KEYBOARD):
# NOTE: for keyboard actions with axis constraints
# ensure that delta is not null
if delta_len == 0 and trs.has_constraint(ConstraintType.AXIS):
if trs.has_constraint(ConstraintType.X):
delta = X_AXIS
elif trs.has_constraint(ConstraintType.Y):
delta = Y_AXIS
else:
delta = Z_AXIS
delta_len = 1.0
dist = Keyboard.value
logger.debug("dist %.4f %s" % (dist, delta.normalized()))
else:
dist = delta_len
# Store feedback for widget
self.feedback_move[:] = delta
steps = max(1, trs.steps)
if trs.has(TransformType.COPY):
trs.feedback = "%s( %s ) %s" % (
i18n.translate("Array"),
trs.steps + 1,
decimal_to_feet_inches(round(dist, 5), 16)
else:
trs.feedback = decimal_to_feet_inches(round(dist, 5), 16)
if delta_len == 0:
# delta not normalizable .. so transform is null
return Matrix()
about = Space.get(trs, self.matrix_step)
# pre-translate
return Geom3d.normalized(
Geom3d.pre_transform(about, Matrix.Translation((trs.step * dist / steps) * delta.normalized()))
@stephen_l would it be possible to implement something like this into the next version? or do you take pull requests?
Would rather implement in Units.to_string handling unit display, but will definitely take a look. Units.from_string should handle fraction input (as it does take care of math expressions) but may require some tricks like 2 + 3/4 in - perhaps even require 2 + (3/4) in (?).
Has there been any update to this?
