I originally misspelled a pset property name, and assigned values to it.
I later fixed the spelling, but now I can't remove that old pset property. Is this possible via the UI?
Could you share the Ifc?
I just had a look on a fresh file and it should rename fine without creating a new line/item,
my best guess is it's probably a bug from a file that's been through multiple Bbim versions
I've now added bug 4696 to address this. Nulling it won't remove the property.
