by steverugi on 25 May 2024, edited 2 Jun 2024
+10 votes
For those, like me, who struggle with selector syntax in Quality and Coordination > Spreadsheet Import/Export I created a table and relevant .json files to start using this great feature in BlenderBIM
in this folder you can access to an .xlsx file with a summary and the .json files named after the summary index number (1st column)
At the end I added some making use of Query and REGEX for advanced criteria
To load a .json file use the DOWN arrow
happy modeling
by Moult on 25 May 2024
+5 votes
This is great! Would you be interested in contributing some of these as presets? That way users can select from a preset dropdown. Stuff like "room schedule" or "door schedule" or "types list" etc sound pretty generic :)
Nice! If you help isolate a set of JSONs perhaps with feedback from other OSArch users to confirm they work generically across multiple disciplines / projects, I can help build a "preset built-in template feature" :)
+5 votes
I added
Door Schedule
Window Schedule
Type Schedule
to the ones already in the folder
Profile Schedule
Space Schedule
I am going to add more if something else comes to mind, or other users post some request here
cheers
by steverugi on 27 May 2024
added
Lintel Schedule
Beam Schedule
Column Schedule
Help
I don't know how to identify IfcElementAssembly , otherwise it would be handy to also add that piece of information in the schedule, like Walls + Coverings (upcoming)
cheers
N
by Nigel on 28 May 2024
Hi @steverugi could a Plumbing fixtures schedule be useful? taps/faucets sinks/basins toilets showers baths etc
by steverugi on 28 May 2024
hi @Nigel
good idea, let me see if I can translate it into something useful, thanks
C
by condur on 28 May 2024
I'll try to make one for reinforcement models. @Moult do we already have any presets that we can use, or they are not implemented yet?
I'd like to do the same for IfcClash, try to build up a library of rules to check for specific scopes. What do you think?
+4 votes
Hi @Nigel
this should work:
I also added storey and most importantly space, I'd expect sanitaryware to be part of one specific bathroom space for instance
it's nr 24 on the Excel list/JSON files
by steverugi on 1 Jun 2024
update
thanks to @Moult 's efforts (despite being busy due to the upcoming new release) now we have a new selector parent to identify elements by their aggregate, I am going to add a new query to the list soon
cheers
ping @theoryshaw
+6 votes
update
Parent selector now available in Spreadsheet Import/Export and Grouping and Filtering
- Aggregated elements schedule added
An example to list all elements aggregated in IfcElementAssembly with name ending in "_wall", note parent.Name to list the aggregator
the above might look trivial to some but for models organized and grouped by IfcElementAssembly it is quite a big deal
cheers
by steverugi on 2 Jun 2024, edited 2 Jun 2024
+6 votes
update (after 240602 release)
now all queries related to elements using a profile are using the new profiles selector
name = profiles.ProfileName
X dimension = profiles.XDim
Y dimension = profiles.YDim
all .JSON files and Excel tables are updated accordingly
