by magicalcloud_75 on 31 May 2024, edited 5 Jun 2024
I wonder why this category shows no display in my viewer, (BimVision). It will come up under 'type' and not site.
What is the logic for this behaviour?
Do i need keep using ifcSpatialElement ifcSite for this. Not sure whcih one to use. Any guidance whatsoever is welcome.
by theoryshaw on 31 May 2024, edited 31 May 2024
+3 votes
Dumb question, is there only the IfcGeographicElementType type, and no IfcGeographicElement instance, in the file?
If so, i think you need to add an IfcGeographicElement instance into the project, for it to be visible in other viewers. could be wrong.
by magicalcloud_75 on 3 Jun 2024
Not in BlenderBIM as class nor in the file. It's really guessing what class everything from topo should be.
Only 'site' seems to come over in IFC.
J
by JanF on 3 Jun 2024, edited 3 Jun 2024
You should use ifc geographic element. https://standards.buildingsmart.org/MVD/RELEASE/IFC4/ADD2_TC1/RV1_2/HTML/schema/ifcproductextension/lexical/ifcgeographicelement.htm
Can you sharethe ifc? There's going to be a different problem if your geographic elements don't show, in my experience they work just fine.
Ifcsite is wrong for this.
And yes @theoryshaw is right, everything with "type" in name is a type, goes in the types group and won't be shown by any viewer.
by magicalcloud_75 on 5 Jun 2024
Attached a blender file .txt as sample.
The source data is from Netherlands3d.eu (.dae as import)
