For those brave souls that sync the .blend/ifc files, do you often get the following error?
And have you noticed, if you try and save again, it usually works without an error.
os: Windows
os_version: 10.0.19045
python_version: 3.11.7
architecture: ('64bit', 'WindowsPE')
machine: AMD64
processor: Intel64 Family 6 Model 158 Stepping 10, GenuineIntel
blender_version: 4.1.1
blenderbim_version: 0.0.240511
last_actions:
# ifcopenshell.api: spatial.assign_container
>>> {"products": [{"cast_type": "entity_instance", "value": 278225, "Name": "Wall"}], "relating_structure": {"cast_type": "entity_instance", "value": 1661272, "Name": "Library"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 774760, "Name": "Wall"}], "relating_structure": {"cast_type": "entity_instance", "value": 1661272, "Name": "Library"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 280057, "Name": "Wall"}], "relating_structure": {"cast_type": "entity_instance", "value": 1661272, "Name": "Library"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 1397997, "Name": "Wall"}], "relating_structure": {"cast_type": "entity_instance", "value": 1661272, "Name": "Library"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 3217755, "Name": "Wall"}], "relating_structure": {"cast_type": "entity_instance", "value": 1661272, "Name": "Library"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 3126989, "Name": "Walls 126:Walls 126:1518668"}], "relating_structure": {"cast_type": "entity_instance", "value": 1658805, "Name": "Details"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 3126981, "Name": "Walls 127:Walls 126:1519197"}], "relating_structure": {"cast_type": "entity_instance", "value": 1658805, "Name": "Details"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 3241743, "Name": "Window"}], "relating_structure": {"cast_type": "entity_instance", "value": 1661272, "Name": "Library"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 3217793, "Name": "Window"}], "relating_structure": {"cast_type": "entity_instance", "value": 1661272, "Name": "Library"}}
>>> {"products": [{"cast_type": "entity_instance", "value": 3219622, "Name": "Window"}], "relating_structure": {"cast_type": "entity_instance", "value": 1661272, "Name": "Library"}}
last_error: Traceback (most recent call last):
File "C:\Users\Ryan Schultz\AppData\Roaming\Blender Foundation\Blender\4.1\scripts\addons\blenderbim\bim\ifc.py", line 360, in execute_ifc_operator
File "C:\Users\Ryan Schultz\AppData\Roaming\Blender Foundation\Blender\4.1\scripts\addons\blenderbim\bim\module\project\operator.py", line 1218, in _execute
bpy.ops.wm.save_mainfile("INVOKE_DEFAULT")
File "c:\Program Files\Blender Foundation\Blender 4.1\4.1\scripts\modules\bpy\ops.py", line 107, in __call__
ret = _op_call(self.idname_py(), kw, C_exec, C_undo)
RuntimeError: Error: Unable to make version backup
Error: Version backup failed (file saved with @)
ifc: 2917_International_Ln.ifc
schema: IFC4
preprocessor_version: IfcOpenShell v0.7.0-f7c03db75
originating_system: BlenderBIM 0.0.240511-6247fb3
