by alb on 13 Jun 2024, edited 16 Jun 2024
Hi, in the building that I am trying to model, there's a room in another room. So when I want to create spaces, I actually need kind of a "donut" Space and a smaller one in the middle. Right now, I just have a big Space (that includes the smaller one) and the small one extra, so basically the small middle room consists of two Spaces at the moment. Like this:
Is there any way to do that? Or is it enough when I have the correct Space Boundaries in the end?
Thanks!
by theoryshaw on 13 Jun 2024, edited 13 Jun 2024
In general, it's always helpful if you can share the .ifc file, or a pared-down version of it, if it's private. Just easier to troubleshoot with an actual file.
by alb on 15 Jun 2024
Ah yes, sure! :) that makes sense. I was talking about the situation on the first and second floor (1. & 2. OG) with the Spaces FlurOG1 and TeekuecheOG1 (resp. FlurOG2 and TeekuecheOG2). Can I "cut" the smaller space from the middle of the larger space?
I think I got it :) I added a cube and a Boolean modifier and cut the Cube from the Space. If there's an easier way you know of, you could still let me know though :)
by theoryshaw on 16 Jun 2024
+4 votes
I would probably do it like this...
It would be a good feature request, however, for the 'Generate space from cursor' functionality to account for rooms within rooms. It doesn't seem to at this point--could be wrong. ping @Massimo
by Massimo on 16 Jun 2024
@theoryshaw maybe it is sufficient to add IfcSpace class to this list
https://github.com/IfcOpenShell/IfcOpenShell/blob/v0.8.0/src%2Fblenderbim%2Fblenderbim%2Ftool%2Fspatial.py#L315
