F
by flukin on 24 Jul 2024, edited 24 Jul 2024
Dear community,
I have started to use IDS in a project of mine with blenderBIM and trying some sustainable specification.
When I am setting up the property about Pset_ManufacturerOccurence, the IDS become invalid. I do assign this property to my ifc model in blenderbim. But the testing reulst failed. Does anybody know whats wrong with it?
I am using blender4.1 with blenderbim 240602, and i use usBIM online editor to write my ids file.
F
My orignial IDS file, since i cant upload IDS here so i change it to text.
F
Ys I did try what u say. But the file still valid.
F
Do I need to import a barcode instead of just type in something?
F
What does "Reserved prefix 'Pset_' for property set name (Pset_ManufacturerOccurence) in the context of Ifc2x3 on property. " mean?
by Moult on 24 Jul 2024, edited 24 Jul 2024
You can see in the audit report that it is actually checking for the pset named ManufacturerOccurence, not Pset_ManufacturerOccurrence. This is probably because there is a typo when creating your IDS (Occurrence has two r)
Another problem is that you are asking for an IfcLabel but the BarCode should be an IfcIdentifier.
You still didn't fix the typo, you need two R in occurrence. It should look like this:
<ids:property dataType="IFCIDENTIFIER" cardinality="required">
<ids:propertySet>
<ids:simpleValue>Pset_ManufacturerOccurrence</ids:simpleValue>
</ids:propertySet>
<ids:baseName>
<ids:simpleValue>BarCode</ids:simpleValue>
</ids:baseName>
<ids:value>
<ids:simpleValue>123456</ids:simpleValue>
</ids:value>
</ids:property>
It means that Pset_ is a special name that only buildingSMART can use. Once you fix the spelling mistake, the error should go away. If it does not, it's a bug with usBIM and feel free to report to them :)
