G
by gabriel_makedrive on 6 Aug 2024, edited 9 Aug 2024
I'm trying to generate a clash from an IFC file and export the results as a BCF with a snapshot. I've already managed to generate the BCF but haven't found a viable way to create the snapshot. Is it necessary to manually change the view for the user and take a screenshot? Or is it possible to process this entirely on the backend?
by Moult on 6 Aug 2024
This is currently only implemented in Blender. We don't yet have a "snapshot" rendering method that works without Blender.
by Bimlooser on 7 Aug 2024
Can you please give me some hints about creating BCF?
Thanks
G
by gabriel_makedrive on 8 Aug 2024
Just to confirm and try to understand what i'm doing wrong, the process in Blender to generate a BCF from clash:
That's the error i get:
Any solution to make this work?
E
by ejs on 9 Aug 2024, edited 9 Aug 2024
And this is exactly what I need to be able to enrich the imported ToDos from Trimble Connect. The viewpoint, camera settings and the snapshot are provided by TC.
G
by gabriel_makedrive on 9 Aug 2024
Thanks
For now i'm using the bcf-api-xml (https://github.com/bimdata/BCF-API-XML-translator), can create and read bcfzip files
For create you can use the function to_zip()
