Hi All. I have a question about filling in Section Marker values. When I create a Section View they automatically appear, but how can I set them to the values I need so that they are visible on both the Floor Plan and Sections?
This is referenced to where they are on a sheet, if you add them to a sheet, it will populate the numbers
Thank you, it worked!
