I would like to ask, if some here are familiar with plugins that can calculate an obstruction angle normal out to the next object in front? The specific usages i am looking into is in the Norwegian building codex for daylight access for dwellings, normally you can not calculate any simplification for rooms if there is an obstruction above 45 degree angle. This is a tedious and time consuming job as you have to manually calculate these by using the 3D modell and use geometry to calculate as shown in the image underneath.
Would there be any plugins that can lets say select a surface, and automatic find the average normal angle to the next object? This would increase the productivity and also ensure its easier to document these angles.
