How Move Wall in Relation to Another Wall
  1. S
    Hello everyone,
    What is the best way to move a wall in relation to another wall
    for example in the image above, how do I move wall B let's say 300mm away from wall A? Given that, once I leave the measure tool to the wall tool the measurement disappears.
    Thanks for your help
  2. T
    I just move it. :)
    that is, i move the wall so it's snapped to the other wall at 0mm. Then i'd move it again to 300mm.
  3. S
    Interesting will try that
  4. S
    @theoryshaw said:
    I just move it. :)
    yes, select G B (pick the vertex looking toward the reference wall) snap it, then G X (or Y) 300 (- if necessary)
  5. C
    If you are working with non orthogonal walls, you can align the walls using Shift C, then move the desired wall pressing G, then Y, Y to move the wall along its relative Y axis also if the global coordinate system is in use.
