IFC Brep from FreeCAD
  1. S
    I'm trying to get a brep from freecad and add it to a IFC.
    It seems to be working, or at least i can create
    #116=IFCSHAPEREPRESENTATION($,'Body','Brep',(#115));
    #117=IFCPRODUCTDEFINITIONSHAPE($,$,(#116));
    However, in BlenderBIM nothing is displayed.
    What am I doing wrong? Attached my files
    Her's my code:
    import ifcopenshell.api.geometry
    import ifcopenshell.util.representation
    import ifcopenshell
    import ifcopenshell.geom
    import ifcopenshell.api.root
    import freecad
    import FreeCAD as F
    # FreeCAD
    doc = F.open("cube.FCStd")
    obj = doc.getObjectsByLabel("Body")[0]
    obj_string = obj.Shape.exportBrepToString()
    # IFC
    model = ifcopenshell.open("empty.ifc")
    element = ifcopenshell.api.root.create_entity(model, ifc_class="IfcFurniture")
    ifcopenshell.api.geometry.edit_object_placement(model, product=element)
    product_definition = ifcopenshell.geom.serialise("IFC4", obj_string, False)
    product_definition = model.add(product_definition)
    print(product_definition)
    element.Representation = product_definition
    model.write("cube_test.ifc")
  2. P
    Work if import back to FreeCAD ?
  3. S
    @paullee
    No, if i import the IFC in FreeCAD, the geometry also doesn't show
  4. P
    Apparently, you doesn't export correctly somehow. I export in FreeCAD and re-import and it works :)
  5. P
    Below are codes generated in FreeCAD console, for reference:-
    Python 3.11.9 | packaged by conda-forge | (main, Apr 19 2024, 18:53:30) [GCC 12.3.0] on linux
    Type 'help', 'copyright', 'credits' or 'license' for more information.
     # Gui.Selection.addSelection('cube','Pad')
    ### Begin command Std_Export
    __objs__ = []
    __objs__.append(FreeCAD.getDocument("cube").getObject("Pad"))
    import importers.exportIFC
    if hasattr(importers.exportIFC, "exportOptions"):
    options = importers.exportIFC.exportOptions(u"/... /cube_ Arch_body_ DUMMY.ifc")
    importers.exportIFC.export(__objs__, u"/... /cube_ Arch_body_ DUMMY.ifc", options)
    else:
    importers.exportIFC.export(__objs__, u"/... /cube_ Arch_body_ DUMMY.ifc")
  6. S
    I know how to export a IFC from within FreeCAD.
    However, I'm trying to export it as a Brep instead of a Mesh to avoid a high Polygon count on more complicated parts.
  7. P
    Oops, missed that point.
    From FreeCAD, export it as Brep by checking the option at Edit - Preference - Export IFC dialog box. You may also check 'User IfcOpenShell Serializer if available'. By both setting, it export and re-imported without problem - both *.ifc attached for reference.
    You may have a look at the importers.exportIFC to see how it use IfcOpenShell serialiser.
    >>> __objs__ = []
    >>> __objs__.append(FreeCAD.getDocument("cube").getObject("Body"))
    >>>     options = importers.exportIFC.exportOptions(u"/...  / cube-Body_as-BREP_IfcOpenShell.ifc")
    >>>     importers.exportIFC.export(__objs__, u"/... / cube-Body_as-BREP_IfcOpenShell.ifc", options)
    >>> else:
    >>>     importers.exportIFC.export(__objs__, u"/... / cube-Body_as-BREP_IfcOpenShell.ifc")
    >>> del __objs__
    >>> ### End command Std_Export
  8. P
    I have a look at the exportIFC.py, found some lines which seems relevant to you? Seems similar...
                                    brep_data = sh.removeSplitter().exportBrepToString()
                                    try:
                                        p = geom.serialise(brep_data)
                                    except TypeError:
                                        # IfcOpenShell v0.6.0
                                        # Serialization.cpp:IfcUtil::IfcBaseClass* IfcGeom::serialise(const std::string& schema_name, const TopoDS_Shape& shape, bool advanced)
                                        p = geom.serialise(preferences['SCHEMA'], brep_data)
    Full paragraph :-
                        # new ifcopenshell serializer
                        from ifcopenshell import geom
                        serialized = False
                        if hasattr(geom,"serialise") and obj.isDerivedFrom("Part::Feature") and preferences['SERIALIZE']:
                            if obj.Shape.Faces:
                                sh = obj.Shape.copy()
                                sh.Placement = obj.getGlobalPlacement()
                                sh.scale(preferences['SCALE_FACTOR']) # to meters
                                # clean shape and moves placement away from the outer element level
                                # https://forum.freecad.org/viewtopic.php?p=675760#p675760
                                try:
                                except TypeError:
                                if p:
                                    productdef = ifcfile.add(p)
                                    for rep in productdef.Representations:
                                        rep.ContextOfItems = context
                                    placement = ifcbin.createIfcLocalPlacement()
                                    shapetype = "advancedbrep"
                                    shapes = None
                                    serialized = True
                                else:
                                    if preferences['DEBUG']:
                                        print(
                                            "Warning! IfcOS serializer did not return a ifc-geometry for object {}. "
                                            "The shape will be exported with triangulation."
                                            .format(obj.Label)
  9. P
    Curious why if IfcOpenShell serialiser is used, the *.ifc become 12.3K from the one without the serialiser 3.1K, 4 times as large?
    @yorik Have a gap to comment? :)
  10. Y
    Just open the two files in a text editor and you'll see why.. The serializer is not optimized for compactness, but on the other hand it recreates a very faithful copy of the brep structure: points -> line -> edge -> wire -> face -> body, everything is there.
