this is the generated bug seen in the video
os: Windows
os_version: 10.0.22631
python_version: 3.11.7
architecture: ('64bit', 'WindowsPE')
machine: AMD64
processor: Intel64 Family 6 Model 151 Stepping 2, GenuineIntel
blender_version: 4.2.0
bonsai_version: 0.8.1-alpha240914
bonsai_commit_hash: c487643
last_actions:
# ifcopenshell.api: geometry.edit_object_placement
>>> {"product": {"cast_type": "entity_instance", "value": 184059, "Name": "Opening"}, "matrix": {"cast_type": "ndarray", "value": [[-1.0, -1.5099580252808664e-07, 0.0, 20.06390380859375], [1.5099580252808664e-07, -1.0, 0.0, -2.7076940536499023], [0.0, 0.0, 1.0, 1.0], [0.0, 0.0, 0.0, 1.0]]}, "is_si": "True"}
# ifcopenshell.api: owner.update_owner_history
>>> {"element": {"cast_type": "entity_instance", "value": 184059, "Name": "Opening"}}
# ifcopenshell.api: geometry.map_representation
>>> {"representation": {"cast_type": "entity_instance", "value": 184074, "Name": null}}
# ifcopenshell.api: geometry.assign_representation
>>> {"product": {"cast_type": "entity_instance", "value": 184059, "Name": "Opening"}, "representation": {"cast_type": "entity_instance", "value": 184086, "Name": null}}
# ifcopenshell.api: void.add_opening
>>> {"opening": {"cast_type": "entity_instance", "value": 184059, "Name": "Opening"}, "element": {"cast_type": "entity_instance", "value": 183181, "Name": "Wall"}}
# ifcopenshell.api: owner.create_owner_history
>>> {"product": {"cast_type": "entity_instance", "value": 184059, "Name": "Opening"}, "matrix": {"cast_type": "ndarray", "value": [[-0.9999999999999887, -1.5099580252808492e-07, 0.0, 20063.90380859375], [1.5099580252808492e-07, -0.9999999999999887, 0.0, -2707.6940536499023], [0.0, 0.0, 1.0, 1000.0], [0.0, 0.0, 0.0, 1.0]]}, "is_si": "False"}
# ifcopenshell.api: void.add_filling
>>> {"opening": {"cast_type": "entity_instance", "value": 184059, "Name": "Opening"}, "element": {"cast_type": "entity_instance", "value": 184013, "Name": "Window"}}
# operator: BIM_OT_hotkey
# operator: BIM_OT_show_openings
# operator: BIM_OT_clone_opening
# ifcopenshell.api: root.create_entity
>>> {"ifc_class": "IfcOpeningElement"}
# operator: BIM_OT_add_opening
>>> {"opening": {"cast_type": "entity_instance", "value": 184059, "Name": "Opening"}, "element": {"cast_type": "entity_instance", "value": 183553, "Name": "Covering"}}
>>> {"product": {"cast_type": "entity_instance", "value": 184059, "Name": "Opening"}, "matrix": {"cast_type": "ndarray", "value": [[-0.9999999999999886, -1.5099580252808492e-07, 0.0, 20063.90380859375], [1.509958025280849e-07, -0.9999999999999887, 0.0, -2707.6940536499023], [0.0, 0.0, 1.0, 1000.0], [0.0, 0.0, 0.0, 1.0]]}, "is_si": "False"}
last_error: Traceback (most recent call last):
File "C:\Users\Dayo\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\bonsai\bim\ifc.py", line 408, in execute_ifc_operator
File "C:\Users\Dayo\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\bonsai\bim\module\model\opening.py", line 871, in _execute
ifcopenshell.api.run("void.add_opening", tool.Ifc.get(), opening=new_opening, element=wall)
UnboundLocalError: cannot access local variable 'wall' where it is not associated with a value
ifc: 00.SJCES - Main Building - 240907 - Window Test.ifc
schema: IFC4X3
preprocessor_version: IfcOpenShell 0.8.1-alpha240914
originating_system: Bonsai 0.8.1-alpha240914-c487643
