since the introduction of double engine for quantity take-off (QTO) sometimes one is prefererable over the other, for those who need to extract quantities this might be of use:
Overall
Bonsai looks better than IfcOpenShell for QTO on the traditional elements like slab, wall, column, beam, saved for the length of last two for which the side dimension is given instead, the same happens to elements not included in this test (Bonsai v0.8.1-alpha240916) like footing beams.
IfcOpenShell
(+) accurate length of all 4 elements (slab, wall, column, beam)
(-) does not calculate Gross and NetWeight based on material density
(-) does not calculate Gross and NetFootPrintArea in walls
Bonsai
(-) uses the
Yvalue for length of columns and beams instead ofZ -
(+) calculates weight based on material density
Both
- (-) no SectionArea calculation of columns and beams available
see table below as summary:
kindly comment if you spot inaccuracies or missing information
thanks and happy modeling
Legend
[-] quantity not available in relevant Quantity set
[O] quantity not calculated
[X] wrong calculation
[V] quantity calculated correctly
