by atomkarinca on 26 Sep 2024, edited 27 Sep 2024
Hi everyone,
When I try to search the query:
Qto_WallBaseQuantities.Width=0.1
I get the error:
__^
Expected one of:
I tried adding escape characters but it didn't work, either. Is there a way I can get this working?
by Bimlooser on 26 Sep 2024
I hadn't tested but try type "0,1" instead of "0.1". Strange behaviour
I guess comma is reserved for concatenating multiple conditions. When I do that it says:
Unexpected end-of-input. Expected one of:
* DOT
@theoryshaw thanks, that worked perfectly. I didn't even need to do double conditions, widths are just round numbers in the project.
For anyone wondering how to add this to a cost schedule template, you need to add double quotes like this:
""Qto_WallBaseQuantities"".""Width"" = ""0.1""
by theoryshaw on 26 Sep 2024
+5 votes
There's probably a better way to do this, but the following works. It accounts for Blender not really returning exactly 0.1
IfcElement, "Qto_WallBaseQuantities"."Width" >= "0.0999", "Qto_WallBaseQuantities"."Width" <= "0.1001"
by steverugi on 26 Sep 2024, edited 27 Sep 2024
I don't think you need to double quote it
IfcWall, "Qto_WallBaseQuantities"."Width" < ".101" works just fine (for 100mm walls in my project)
cheers
by atomkarinca on 27 Sep 2024
@steverugi i meant when you want to make a template and import it as a cost schedule, you need to have the query inside quotes. for instance:
Hierarchy,Identification,Name,Unit,Property,Query
5,XX,100mm wall,unit,NetSideArea,"IfcWall, PredefinedType=STANDARD, ""Qto_WallBaseQuantities"".""Width"" = ""0.1"""
by steverugi on 27 Sep 2024, edited 27 Sep 2024
Hi @atomkarinca
the following two queries in my .csv file used to import a cost schedule
produce the same result:
well, at least on my 2 laptops :)
cheers
PS as a general rule, what is good for the Search in "Grouping and Filtering" or Spreadsheet Import/Export can be used in the Query column in the .csv to import a cost schedule, after all they all use the same 'Selector' (to the best of my knowledge)
@steverugi sorry, i was purely talking about writing csv in a text editor. when you create it in a spreadsheet editor, it will already format it accordingly.
sure, no problem
For those who are not too familiar with the subject, in Bonsai you can create a .csv table where elements can be grouped in a hierarchical structure and according to some particular criteria (i.e. class, location, type..) and their common quantity can be extracted and used in a cost schedule, or they can be just exported as table with Spreadsheet Import/Export using the same query.
What I showed above is from the actual .csv file I use as template and adjust according to my needs
cheers
