Bonsai/Blender IFC export Object placement
  1. F
    I am working with a script for Blender/Bonsai to model some beams with the pre-defined US steel catalog. To my surprise, one of the beams ends up in the wrong location after export to IFC (see screenshots), although all of them are created and exported the same way. Any ideas where this might come from?
  2. S
    hi @fnoi
    when you save the model on the left to .ifc and reopen it in Bonsai does it look the same?
  3. F
    hello @steverugi, thanks for your reply. indeed it didn't look the same after re-opening the file in blender/bonsai.
    the issue was hiding in a previous processing step- and placement of objects in bonsai using centerpoints. transforming to extrusion center/ "start" of the object caused this issue.
    consider issue solved / not a bonsai problem
