Dumb question, how do you draw a wall on the basement level, 10ft down, for example?
With 0.7.0, you could highlight the buildingstory collection, you'd like the wall to associated with, but doesn't seem to work with 0.8.0.
@theoryshaw In Spatial Decomposition panel you can select Basement and then click the "Set as Default" button. It should change the default collection. Every object is added to the default collection.
See...Dumb question. :)
Your answer, however, was most brilliant. :)
Thanks.
For those who don't know where that is UI wise
