by Benny on 9 Nov 2024, edited 20 Feb 2025
I've been away from Bonsai for a time and now that I'm going to continue on a project I've apparently forgotten how to put patterns on the objects in elevation mode.
How can I make my patterns appear on elevation view.
I would like to show lines on the facades that show that it is a wooden panel. In my previous project I managed to create my own pattern (css) just a simple line pattern to apply to elevations but it worked. Now I don't manage to get any pattern on the elevation views to show at all.
Is there something strange going on here since the move gizmo is not visible properly?
by theoryshaw on 9 Nov 2024
Unfortunately I don't think Shapely fill mode works right now...
https://github.com/IfcOpenShell/IfcOpenShell/issues/5676
by Benny on 10 Nov 2024
Thank you very much for the response and clarifying!
J
by jes_r on 20 Feb 2025, edited 20 Feb 2025
is there an alternative solution or something? Running into the same problem ;)
by Ace on 20 Feb 2025
A work around for now would be to use a Fill area with no outline and draw it over the elevation in 2d, atleast until the background fills are sorted.
J
Yeah ok, so no real fix yet. Can't imagine @theoryshaw makes his elevations etc this way?
Or does he render the materials in elevation view in some way?
by theoryshaw on 20 Feb 2025, edited 20 Feb 2025
Yes, I use external styles, and turn on the rendering settings for BB drawings.
You can sync the following repo, to give you a sense of how we set things up:
https://hub.openingdesign.com/OpeningDesign/Restaurant_MPM/src/branch/main/Open/Models/BlenderBIM
It would be nice to get svg fills to work again on projections and have it accommodate geometry and drawing rotations, and/or skews relative to the camera...
https://github.com/IfcOpenShell/IfcOpenShell/issues/3867
