Let's say you import a 2d profile from a dxf, and you'd like to convert it to an IfcArbitraryClosedProfileDef?
Anyone have an easy way to do so?
As you can see, my joining technique did not work. :)
Currently I model it again with the dxf as snapping point reference, so not the best way either. Certainly not with a lot of rounded corners...
Something like this would help?
Is this a trick question? ;)
very cool!
@theoryshaw haha, no, I just wanted to make sure that this is the right approach.
You know you created a monster now, right? ;)
Possible to convert profiles with a void inside?
@theoryshaw it should be possible now, but you have to draw the faces.
Big time!
