Syntax in Spreadsheet Import/export
  1. A
    I'm trying Import/Export for values ​​obtained with "Manual Quantification" but I can't export the value.
    Normally I use IfcElement as a filter and custom pset attributes (Pset_Name.Pset_Property) without problems but if I want to include a value generated with Manual Quantification ("My_Qto.Long" for example), in that field the value obtained is N/A.
    It's probably a problem with the selection filter but I don't know how to modify it.
    Has anyone done something similar? Any suggestions?.
    (I think it's related to what was indicated in the thread
    https://community.osarch.org/discussion/2613/use-property-value-for-quantity-schedule
    and a possible alternative to fill custom psets with quantities)
  2. S
    Hi @avico
    here is an example I just tried with a model I am working on
    I select a pile and manually extract its length saved as My_Qto.MyDimension, using Gross Z from IfcOpenShell engine:
    this is the same custom quantity in quantity set:
    I use Spreadsheet Import/Export
    and this is the output (only 1 pile was used for the manual calculation)
    you also need to make sure that the manual take-off saves in a custom quantity property indide Quantity Sets
    please advise
  3. A
    Thanks @steverugi ,
    In the end it is my mistake. The first elements of the exported file do not have values ​​so it always appeared N/A. Looking at all the values ​​the export is correct.
    With this you can fill user Psets with quantities simply by exporting to csv, opening with openoffice and copying the corresponding cell
