Is it possible to read (and write) the IFCSIUNIT of an IFCPROPERTYSINGLEVALUE with Bonsai or any other IfcViewer? In my case i'd like to see "101.2 cm" displayed
You could see the degub panel in Bonsai under "Quality and coordination tab"
Thank you for the hint! Do you mean here:
@Rio
with the debug panel you can visualize the IFC item (#43 or #44 above) by entering it in the top bar just above Inspect From STEP ID and click it afterward
or you want to export the value into something like a .csv table?
