Can you teach be some BlenderBIM basics?
  1. R
    Hello,
    Can you teach me some Bonsai basics? I wish to model a CLT hut. The wall, floor & roof have several layers.
    I want to:
    1. Create a library of materials (CLT, Concrete, Wood Fibre Insulation, Cladding, Tiles
    2. Create a library of walls, floor, roofs.
    3. Create the hut.
    4. Animate the assembly sequence.
    5. Create CNC file for the CLT
    6. Create BLT file for the walls.
    I will gladly pay for your time.
    Thanks,
    Gaurav
  2. S
    @rampalg
    1. Create a library of walls, floor, roofs.
    1. Create the hut.
    1. Animate the assembly sequence.
    1. Create CNC file for the CLT
    1. Create BLT file for the walls.
    If I may, you could start with sharing your dwg or sketch to understand the extent of your exercise, but being a hut it shouldn't be that big
    I had to look it up to see what CLT and BLT mean.. that piece of info might be useful too, maybe?
    I think points 1 to 3 are not difficult to learn with available videos on YouTube but won't take long to go through them
    does nr 4 go along with a 4D work plan or just a Blender sequence?
    no idea about the last two.. :))
  3. T
    I could probably help you.
    Have been using BB for a couple years now. Here's our work: https://community.osarch.org/discussion/1423/live-projects-an-exploration/p2
    Currently working with @axelp on introducing new workflows from Bonsai to CADwork, and hopefully directly to CNC, in the future.. Still very early days, however.
    I'm an architect by training, but know a 'little' python.
    In general, i think figuring out a workflow from Bonsai to CNC would benefit a lot of people, would probably be worth a concentrated funding campaign to bring in a core developer to figure it out.
    I ping @axelp here too, as he's thought about this alot.
  4. R
    @steverugi said:
    @rampalg
    1. Create the hut.
    I've spent some time on Youtube but it's a little more intricate than I thought. I'm using Bonsai 4.2 and the settings seemed to have changed.
  5. R
    Yes, I think there is a need to go to CNC. Is there . I'd rather not go through CADwork as it's closed source.
    Will BlenderCAM work for CNC of CLT layers? Has anyone done this?
    (CLT: Cross Laminated Timber)
    (BLT- CNC format for Wall construction)
  6. S
    @rampalg
    well, it has changed a bit, can you share anything about the hut you need to build? a dxf perhaps?
    but this can also be a quick gig for someone who's interested in accepting your offer too?
    cheers
  7. J
    There are plugins for g-code export directly from blender, but I can't find anything about blt, do you have some references?
  8. R
  9. R
    @steverugi said:
    @rampalg
    cheers
    I will get back to you shortly.
