TypeError: ‘NoneType’ object is not subscriptable
  1. O
    I'm making a Blender script to decimate each selected object from an IFC file. But in some IFC files appears the following error: TypeError: ‘NoneType’ object is not subscriptable
    `import bpy
    def is_valid_mesh(obj):
    if obj.type == 'MESH' and obj.data and len(obj.data.vertices) > 0 and len(obj.data.polygons) > 0:
        return True
    return False
    for obj in bpy.context.selected_objects:
    if is_valid_mesh(obj):
        try:
            decimate_modifier = obj.modifiers.new(name="Decimate", type='DECIMATE')
            decimate_modifier.ratio = 0.1
            bpy.context.view_layer.objects.active = obj
            bpy.ops.object.modifier_apply(modifier=decimate_modifier.name)
            print(f"Decimate modifier applied to {obj.name}")
        except RuntimeError as e:
            print(f"Failed to apply Decimate modifier on {obj.name}: {e}")
    else:
        print(f"Skipping {obj.name} (invalid geometry)")
    try:
    bpy.ops.bim.update_representation()
    print("Update Representation executed successfully.")
    print(f"Failed to execute 'Update Representation': {e}")
    output_path = "route/to/output/path"
    try:
    bpy.ops.bim.save_project(filepath=output_path)
    print(f"IFC file exported successfully to {output_path}")
    print(f"Failed to export IFC file: {e}")`
