TL;DR Any electromagnetic risk can be solved theorically with simulation
of course, i want to help as much as possible.
1st We should start with a risk management software, actually I am using CDrisk, but ORE could be a better base for start or any free worksheet.
https://www.opensourcerisk.org/ (ORE)
https://electrical-engineering-portal.com/download-center/electrical-software/lightning-protection-risk-assessment-calculator
2nd Copper conductivity is 100% and aluminion is 61%, when is pure, for a BIM and 3D modeling is necessary determinate the materials.
3rd Exist multiple lightning calculation method, but the most used and easy to understand is the Sphere Method, actually used for DDS-CAD.
4th the materials can be determinated for multiple reasons and factors, but the ideal is use copper.
Descripting Sphere method:
A imaginary sphere or ball, that represent an electron, is moved for all our 3D or 2D building, the Lightning Rod should be ubicated strategically in the site that help to protect our building, generally in the edges.
the Sphere Radio is determinated for our Risk Management Software, such Radio can be different according to differente standard and per country.
Traditional Workflow:
After determinate our Sphere Radio, and ubicate our Lightning Rods, we should connect our Grounding Rod or Grounding Mesh
After connect our device,s the cable size should be calculated, for this we should use our free worksheet
https://electrical-engineering-portal.com/download-center/electrical-ms-excel-spreadsheets
At same time our Grounding Rod or Mesh should be calculated with another use our free worksheet but take in consideration than each country have their own requeriment.
https://electrical-engineering-portal.com/download-center/electrical-software/earthing-mat-design-for-substation
Pros:
easy to draw in a CAD program.
Cons:
no effective method
this is just theorical
standard change each year in every country
the calc method for the risk software could be modified intentionally for sell mor lightning / grouding rod / meshhis
not every risk software have info for every country.
Solution:
Simulate the lightning Strike with an Electromagnetic Software, multiple software could be solve this but there exist different algoritm to solve this, I mean, is similar to Structural Analysis, using FEM and others methods.
Similar to LED lighting Calc, the Grounding Rod or Mesh should be calculated by specialized software.
Simulate a Lighitning Strike could find hidden errors that using a spreadsheet could not determine.
PD: Actually I am exploring Simulation Software and Actually I can not help in this part, but OpenEMS or FreeCAD EM Workbench theorically should should be able to create these simulations
PD 2: Same method apply for Sub-Station design and Diesel Generator size (GenSet)
https://electrical-engineering-portal.com/download-center/electrical-software/size-diesel-generator
PD 3: all basic necessary sheet can be found for free in the internet.
PD 4: I am student, I could fail in some part, but I am being very very rigorous in find the right workflow.
PD 5: according to internet, the best for mentioned work is:
https://www.emworks.com/
https://www.ansys.com/about-ansys/advantage-magazine/volume-x-issue-1-2016/lightning-strikes-more-than-once
https://etap.com/
https://www.mathworks.com/products/simulink.html
