So I have an Architectural model with around 20k elements and I want to delete everything but the concrete shell. Selecting 1000 objects and doing the ifcdelete command takes forever to compute (like 10mins+). Is there a fast way to do this?
Thanks!
Thanks!
@ShellNotClosed
you can try to use a patch (instead of IfcWall use the class you need to export/keep)
please advise
Unfortunately, deleting stuff enmass is slow.
Considering you only need one thing, could you link the file, and bring in the geometry?
@steverugi said:
@ShellNotClosed
please advise
Worked! Thank you!
