How to 'Bend' an object in Bonsai?
  1. I
    Hello, I'm required to have curved structural I-Beams (arched beam 15 degrees around an axis), is there a correct way of doing this in Bonsai?
    I am new to Bonsai but have used Blender for many years. I understand using the usual blender editing won't work for ifc objects.
    Could someone kindly give me some direction here?
    Kind regards.
    Edit: I suppose just need to create a custom bespoke ifc object.
  2. T
  3. G
    You can indeed transform any vanilla Blender mesh object into an ifc object. Just remember to apply any modifier beforehand because these are not supported in Bonsai (yet ?).
  4. M
    The correct way to do this would be to use a curve as the axis of a standard profiled IfcBeam. Unfortunately right now as you've guessed we only support editing a single straight segment.
    That said, we're working on it and there has been a lot of work recently in improving the way we handle curves, so watch this space :) This is also relevant for curved walls, curved coverings, etc.
    In the meantime as mentioned already you can just model it manually as a mesh and assign it as an IfcBeam.
  5. K
    IfcPipeSegment, IfcDuctSegment and IfcCableCarrierSegment are straight lines, but IfcPipeFitting, IfcDuctFitting and IfcCableCarrierFitting are in the Predifined type enumeration BEND. It looks like they are separated by Segment and Fitting.
    I guess it's because that's what the actual material to be arranged is, but it's hard while modeling the placement :)
