V
by viktor on 5 Jan 2025, edited 7 Jan 2025
I need to format a number for *.ods spreadsheet export, for example an area of a slab 24.16123648 -> 24,16 (goal is to get two decimals and a comma as a delimiter)
Here is my settings number(round({{value}}, 0.01), ",")
The issue is that in the *.ods output there is an extra apostrophe character before the number:
by theoryshaw on 5 Jan 2025
I can't replicate this. What version are you on?
V
Just in case, I am enclosing the .ifc test file and corresponding CSV Settings (I have changed the file extension to .txt, because attaching of *.json is forbidden).
by steverugi on 6 Jan 2025
I don't have the single quote either, but I noticed some odd behavior with comma separator in LibreOffice (not using it that much)
by the way, if you need to remove the preceding single quote you can use Data > Text to Columns like
V
by viktor on 6 Jan 2025
The USA locale in your screenshot @steverugi gave me an idea to try to change the Libre Office locale settings.
However I am not sure it is 100% Libre Office's fault because when I don't use the CSV formatting in Bonsai, the single quote does not appear even with the czech locale.
V
Hmm, so even with the USA locale, despite the single quote is not shown, the number is not treated as a number in my Libre Office, so I cannot do operations like SUM...
by avico on 6 Jan 2025
@viktor,
a workaround would be export as "*.csv", edit with a text editor (like notepad), changing separator to ";" and decimal separator to ",". Later, import with libreoffice calc
OK
I set my LibreOffice Calc with Czech Locale Setting
I select the cells having a single quote before the number
I go to Data > Text to Columns and set Tab as below:
to make them a number I can operate with (see sum at the bottom)
V
Thanks for the workarounds @avico @steverugi I can also omit the Bonsai's formatting step and set the desired decimal places afterward in LO's Format Cells
Do you think I should file a bug report?
I was actually about to suggest it..
Do yoy think I should file a bug report?
Yes, I think it's worth mentioning it
V
by viktor on 7 Jan 2025
Ok, reported . And I found a funny workaround:
there is no issue when I use number(12345, ",") instead of the number({{value}}, ",")
