IfcTask & IfcTaskTime - ifcopenshell
  1. M
    i'm trying through code to be able to iterate through all IfcProducts, and to list and IfcTask and IfcTaskTime properties.
    for example i need to extract IfcTaskTime dates.
    type: IfcTaskTime
    DataOrigin: USERDEFINED
    UserDefinedDataOrigin: None
    DurationType: None
    ScheduleDuration: None
    ScheduleStart: 2025-12-01T08:00:00
    ScheduleFinish: 2025-12-03T16:00:00
    EarlyStart: None
    EarlyFinish: None
    LateStart: None
    LateFinish: None
    FreeFloat: None
    TotalFloat: None
    IsCritical: None
    StatusTime: None
    ActualDuration: None
    ActualStart: None
    ActualFinish: None
    RemainingTime: None
    Completion: None
    i can find this information, but i cant seem to link it back to the IfcTask, which is linked with IfcProduct in this example.
    IfcPile is in a relationship with IfcTask using IfcRealAssignedToProduct,
    IfcTaskTime is in a relationship with IfcTask using IfcTealAssignedToProcess.
    i can see this in the the .Ifc read in notepad. i just cant seem to figure out how to read IfcTaskTime, and see what IfcTask is associated an in turn also know which IfcProduct is assigned.
    my latest attempt look like this, greatful for any support or ideas, where i might be going wrong
    import ifcopenshell
    Load the IFC file
    ifc_file_path = r"location to ifc file"
    ifc_file = ifcopenshell.open(ifc_file_path)
    for rel in ifc_file.by_type("IfcRelAssignsToProcess"):
    print(f"RelatingProcess: {rel.RelatingProcess}")
    print(f"RelatedObjects: {rel.RelatedObjects}")
    Debug: Print all IfcRelAssignsToProcess objects and their details
    print("\n--- Debug: IfcRelAssignsToProcess Relationships ---")
    for related_obj in rel.RelatedObjects:
        print(f"  RelatedObject: {related_obj}")
        if related_obj.is_a("IfcTaskTime"):
            print(f"    Is a TaskTime: {related_obj}")
            print(f"    TaskTime ScheduleStart: {getattr(related_obj, 'ScheduleStart', 'No ScheduleStart')}")
            print(f"    TaskTime ScheduleFinish: {getattr(related_obj, 'ScheduleFinish', 'No ScheduleFinish')}")
            print(f"    TaskTime ScheduleDuration: {getattr(related_obj, 'ScheduleDuration', 'No ScheduleDuration')}")
    Extract tasks related to IfcPile
    tasks_related_to_piles = []
    for rel in ifc_file.by_type("IfcRelAssignsToProduct"):
    if rel.RelatingProduct.is_a("IfcPile"):  # Check if relating object is IfcPile
        tasks_related_to_piles.extend(rel.RelatedObjects)
    Debug: List the tasks related to IfcPile
    print("\n--- Debug: Tasks Related to IfcPile ---")
    for task in tasks_related_to_piles:
    print(f"Related Task: {task}")
    Extract TaskTime relationships
    results = []
    task_name = getattr(task, "Name", "Unnamed Task")
    task_time_details = "No TaskTime Assigned"
    print(f"Checking Task: {task_name} for TaskTime...")
        print(f"  Checking RelatingProcess: {rel.RelatingProcess}")
        if rel.RelatingProcess == task:  # Match task with process
            print(f"    Found related task: {task.Name}")
                print(f"    Checking related object: {related_obj}")
                if related_obj.is_a("IfcTaskTime"):  # Check for IfcTaskTime
                    task_time_details = f"Start: {getattr(related_obj, 'ScheduleStart', 'No Start Time')}, Finish: {getattr(related_obj, 'ScheduleFinish', 'No Finish Time')}, Duration: {getattr(related_obj, 'ScheduleDuration', 'No Duration')}"
                    print(f"    Found TaskTime: {task_time_details}")
    results.append((task_name, task_time_details))
    Output results
    print("\n--- Results: Task and TaskTime Details ---")
    for task_name, task_time_details in results:
    print(f"Task: {task_name}, TaskTime: {task_time_details}")
  2. M
