L
by luansantann on 22 Jan 2025, edited 6 Feb 2025
+4 votes
Hi, I am an architecture student at the Federal University of Bahia here in Brazil. I’ve been working on my final graduation project using Blender in combination with the Bonsai add-on to manage IFC files in BIM. However, the model of the building I am studying was created in Archicad, with its ornaments stored in a separate library.
The current issue is that, when exporting the file from Archicad and importing it into Blender, some ornaments/elements are not showing up. I tested it in another viewer (Bimcollab), and the model appeared correctly there, with all elements visible.
Do you have any idea what could be causing this issue with the model’s import into Blender? I’m also attaching some screenshots of Blender and Bimcollab to illustrate what I’m describing.
I would greatly appreciate your help.
Best regards,
Luan
by theoryshaw on 22 Jan 2025, edited 22 Jan 2025
Very cool. Can you share the file here? Is easier to troubleshoot.
If the file is private, you can upload here: https://docs.google.com/forms/d/1CVVw98Sb5GDZZb4NYjdCrg3JLpREzSSes2Xgq0Bt5I0/viewform?edit_requested=true
The file is only seen by the core Bonsai developers.
L
by luansantann on 25 Jan 2025
Good morning! Just shared the file. Thank you very much!
by Moult on 26 Jan 2025
Can you please let me know the GlobalID (GUID) and name / description of 3 elements that show in other viewers that don't show in Blender?
by Andrej730 on 6 Feb 2025
@luansantann
It seems to be old release issue. Can you please try the latest build from releases? https://github.com/IfcOpenShell/IfcOpenShell/releases/
by Moult on 6 Feb 2025
The screenshots still look different, see the window holes at the bottom?
by brunopostle on 6 Feb 2025
..also cornices are not mitred at the corners
Overlooked it, right, there's an issue with loading openings on that bottom wall. Posted it here - https://github.com/IfcOpenShell/IfcOpenShell/issues/5999#issuecomment-2639876204
