IfcOpenShell - building a tree and select by ray
  1. C
    I followed the idea in the docs about building a geometry tree and selecting by ray.
    However for some reason the following code doesn't work:
    import multiprocessing
    import ifcopenshell
    import ifcopenshell.geom
    import logging
    logging.getLogger().setLevel(logging.DEBUG)
    ifc_file = ifcopenshell.open(r'tests\models\cube.ifc')
    tree = ifcopenshell.geom.tree()
    settings = ifcopenshell.geom.settings()
    settings.logger = logging.getLogger()
    iterator = ifcopenshell.geom.iterator(settings, ifc_file, multiprocessing.cpu_count())
    i = 0
    origin = (0., 0., 0.)
    direction = (1., 0., 0.)
    length = 50.
    if iterator.initialize():
        while True:
            # Use triangulation to build a BVH tree
            tree.add_element(iterator.get())
            i += 1
            if not iterator.next():
                break
        logging.debug(f"{i} elements added to tree.")
        results = tree.select_ray(origin, direction, length)
        print(f"Number of results: {len(results)}")
        for result in results:
            print(ifc_file.by_id(result.instance.id()))
    There aren't any errors, my results is just empty.
    However, when I don't use the iterator, like this:
    import ifcopenshell
    import logging
    i = 0
    length = 50.
    mytree = ifcopenshell.geom.tree(ifc_file, settings)
    results = mytree.select_ray(origin, direction, length)
    Then I get the results I expect. So I'm pretty sure I'm using the iterator wrong.
    Any advice much appreciated, thanks.
  2. C
    Note to my future self, using tree.add_element(iterator.get_native()) works.
