Beginner's question about svg file
  1. A
    Hi everyone, I'm starting to study bonsai these days. I encountered a problem viewing svg files. When I view them from Firefox I can see the dimensions in the correct scale. However, in other programs such as the Affinity suite they have an incorrect scale. Do any of you know how to get around this issue. maybe it is possible to convert svg to pdf directly in bonsai? Thank you
  2. V
    Hello! I use Inkscape happily and you can use it for pdf creation.
  3. A
    thanks so much for the reply. I tried with Inkspace and the display is correct. However, I think that the possibility of exporting PDF files would be useful
  4. T
  5. A
  6. T
    Cool. Can you get it to work on your side?
    I unfortunately can't get it to work, on my side, now. ha.
  7. A
    same for me. It doesn't work. I also tried inserting the entire inkspace's directory but nothing...
