by mastrolube on 11 Feb 2025, edited 11 Feb 2025
Hi there, I want to join two elements of the same type that my modeller extracts as two separate entities.
I tried to select them and press CTRL+J to join them but the result is not appropriate because it's somehow distorted (look at the screenshot). How can I do this the right way?
Thanks,
Dennis
by Andrej730 on 11 Feb 2025
@mastrolube sounds like a possible bug. Can you please share example .ifc file to reproduce the issue?
Seems to be some float precision error when saving geometry to IFC, I'll investigate.
+4 votes
Okay, I think it's fixed, new build will be available shortly in https://github.com/IfcOpenShell/IfcOpenShell/releases
https://github.com/IfcOpenShell/IfcOpenShell/commit/f6087613f06a1e36f970dedab276960739e87727
