BCF in IfcOpenShell
  1. S
    I've started using IfcOpenshell for a project a month ago and now trying to create a bcf file using bcf library, I'm facing some problems regarding viewpoints.
    It seems like I simply cannot create viewpoints which would work. I've read the documentations multiple times but I'm clearly missing something. Could someone help me differentiate between VisualizationInfo and VisualizationInfoHandler?
    What is the most straight-forward way to create a topic with a viewpoint to an specific Ifc Entity (using GUID for example)?
    Why this code doesn't show any viewpoint when I load it in a software while in code I can see that there is a viewpoint as VisualizationInfoHandler?
    viewpoint = topic_1.add_viewpoint(entitiy_list[0])
    Any help would be appreciated, thanks!
  2. A
  3. S
    Thanks Andrej,
    However, since I haven't worked with bonsai, I couldn't make much of it. It still doesn't make it clear why I cannot create a functional viewpoint.
