Anyone got any clever ideas on how I can remove a Property from a Pset. The catch is that the Property exists twice in the PropertySet, once with the correct Value, once with the string "Error".
So far my attempt with ifcopenshell has stalled as I can't seem to pull Properties from a Pset if they exist twice, IOS just gives me one of the two.
import ifcopenshell
import ifcopenshell.util.element
from pathlib import Path
from pprint import pprint
ifc_path = r"./mdl/"
ifc_glob = Path(ifc_path).glob("*.ifc")
guid_fpid_dict = {}
for ifc_file in ifc_glob:
mdl = ifcopenshell.open(ifc_file)
objs = mdl.by_type("IfcBuildingElementProxy")
for obj in objs:
guid = obj.GlobalId
fpid = ifcopenshell.util.element.get_pset(obj, name="MyPset")
guid_fpid_dict[guid] = fpid
pprint(guid_fpid_dict["ExampleGlobalID"])
The resulting dict only contains one instance of the Property, rather than the two I know it has. I assume this is because the IFC is so dodgy that IOS wasn't built to expect it.
I would love to fix at source instead but that is just as much of a struggle.
