[IFC] List of tools for programming for IFC
  1. B
  2. M
    I find this stack incredibly Windows-centric. Part of the reason I prefer IfcOpenShell, apart from the Python bindings which are a huge time-saver for rapid prototyping, is that it is much easier to build platform agnostic with.
  3. B
    I should share my Perl module for reading and writing IFC files, it is very much limited to functionality that I specifically need, but somebody may find this useful:
    BitbucketIt also includes a vim syntax highlighting file for IFC files which makes them much easier to read
  4. M
  5. B
    @Moult I'll add a wiki entry for File::IFC. The documentation is in perl pod format, so I don't duplicate it in the README. Here's the documentaiton for the base class should anyone be interested:
    NAME
    File::IFC - Industry Foundation Classes
    SYNOPSIS
    A tool for writing IFC STEP files for Building Information Modelling (BIM)
    DESCRIPTION
    File::IFC contains basic methods for reading and writing IFC files. To write real-world IFC files you probably want to use the sub-class File::IFC::Helpers, which contains methods for assembling headers, components etc...
    METHODS
    new Create a File::IFC project like so:
         use File::IFC;
         $ifc = File::IFC->new;
    FILE_XXXX
    Add a header item to the project, these methods are created on the fly:
         $ifc->FILE_FOP ('Some text', ['a', 'sub', 'list']);
    IFCXXXXX
    Add entities to the project, these methods are created on the fly:
         $foo = $ifc->IFCFOO;
         $foo->Add ('Some text', undef, 12.0);
         $bar = $ifc->IFCBAR ('Some other text', undef, 12.03, '.ELEMENT.', 1.0E-05);
         $ifc->IFCBAZ (undef, 'More text', $foo, $bar);
         $ifc->IFCNOO ($foo, [0.0,1.0,0.0], undef, [$foo, $bar]);
    Note, to force a number to be interpreted as a string, prefix it with 'STRING:'
         $ifc->IFCNAR ('Year', 'STRING:2013');
    Note, this library does no entity validation, you can create any method name you like, say $ifc->IFCWHATEVER(undef), and #123=IFCWHATEVER($); will be written to the file.
    Parse
    Alternatively, parse existing IFC data (this expects an array of lines):
         $ifc->Parse (@lines);
    Dump Text
    Generate a IFC formatted data as an array of lines:
         @list = $ifc->Dump;
    ..or join it all together as a single text blob:
         print $ifc->Text;
    This results in text output like so:
         ISO-10303-21;
         HEADER;
         FILE_FOP('Some text',('a','sub','list'));
         ENDSEC;
         DATA;
         #1=IFCFOO('Some text',$,12);
         #2=IFCBAR('Some other text',$,12.03,.ELEMENT.,1.E-05);
         #3=IFCBAZ($,'More text',#1,#2);
         #4=IFCNOO(#1,(0,1,0),$,(#1,#2));
         #5=IFCNAR('Year','2013');
         ENDSEC;
         END-ISO-10303-21;
    Cache_Ids
    Build a lookup table of entity ids (optional, this just speeds up the Get_Id() method):
         $ifc->Cache_Ids;
    Renumber Merge_Ifcrel
    Go through list of entities and renumber without changing order (the data is stored as a big list, this just deletes empty list entries):
         $ifc->Renumber;
    Merge entities that specify a relationship such as IFCRELASSOCIATESMATERIAL, IFCRELCONTAINEDINSPATIALSTRUCTURE and IFCRELAGGREGATES:
         $ifc->Merge_Ifcrel;
    i.e. multiple entries like this get removed:
         #25=IFCRELAGGREGATES('0wsQ2vBzIYI3uTHLpG2INA',#5,$,$,#19,(#24));
         #30=IFCRELAGGREGATES('0dUwp9Ptxt608YBTVMwlQQ',#5,$,$,#19,(#29));
    ..and replaced by a single entry like this (note that as entries are removed, subsequent entries are renumbered):
         #1439=IFCRELAGGREGATES('2OknSXOQLN6pcUngENnLLw',#5,$,$,#19,(#24,#28));
    Refcount
    Count number of references to each entity, increments _refcount for each entity found:
         $ifc->Refcount;
    Get_Id
         $id = $ifc->Get_Id ($entity);
    Returns an integer id prefixed with a hash, e.g: #1234
    FUNCTIONS
    guid
    Create a random (probably) unique UID:
         $string = guid();
  6. M
    Very cool! Thanks for adding it to the wiki!
  7. M
  8. M
    @mko - great project! Would you like to add it? It is a wiki :)
  9. M
    will register soon :)
  10. D
  11. D
  12. M
    Hi Ducan,
    Yes sorry for the delay, still rather busy at the moment but I will try to anwser briefly. So, ... good question :) As I've mentioned here [1], Stepcode is a set of tools and a library that can parse Step files (and Ifc files by extension). As a C library, Stepcode is used to auto-generate custom C libraries from Step/Ifc file schemas with object definitions. These generated libraries are usefull if you what to build an application based on these specific Step/Ifc objects (being a C lib, you have very good performances with large objects). Thomas Paviot, the author of PythonOCC [2] is one of the maintainer of the library if I'm correct. Stepcode is, as far as I known, one of the oldest open source library that can do the job. Today, you'll find some more "modern" version of it. IfcOpenshell for example (which is written in C++) has implemented it's own parser. In the same domain there is xBim [3] also.
    Hope that can help,
    best.
    Milovann
    [1] https://www.continuum.codes/stepcode/
    [2] https://www.continuum.codes/pythonocc/
    [3] https://www.continuum.codes/xbim/
  13. B
  14. D
