by arunarchitect on 8 Mar 2025, edited 17 Mar 2025
Whenever I open the IFC file the roof geometry is hidden, this happened when i changed my bonsai version. The roof object is there in the Outliner, it appears when a new roof of same type is added or if we edit the roof from Outliner. The Roof type preview is also missing. The geometry is visible in Bimvision. Is this a bug or should I change the settings? Attached the files and screenshots, Thanks in advance!
by steverugi on 8 Mar 2025
@arunarchitect
odd, to show your roof I selected it from the Outliner and clicked on the Representation (I also assigned "Roof" material to it)
but when I save the model it doesn't show
since you have this roof as an IfcRoofType I unlinked the object (making it just a mesh) and used IfcElement Roof instead
file attached
but I still don't know what went wrong in the first place..
by sjb007 on 8 Mar 2025
I had a very similar sounding issue with a window that I raised an issue for: https://github.com/IfcOpenShell/IfcOpenShell/issues/5880
by arunarchitect on 10 Mar 2025
@steverugi said:
since you have this roof as an IfcRoofType I unlinked the object (making it just a mesh) and used IfcElement Roof instead.
Thank you! Now the roof appears, but the challenge is that I cant easily edit the roof structure as before if needed.
by steverugi on 10 Mar 2025
OK, this time around I removed the void in the roof and it looks OK, still editable, please try
by arunarchitect on 17 Mar 2025
aah yes, it works now. the void is the culprit here : ) . sad part is that : ( actually I wanted that void in the roof geometry. Thank you for helping @steverugi
