Reorder properties in PSET
  1. M
    Hi there!
    Quick question: is it possible to reorder the property rows in the custom PSET?
    For example, move "Bentonite" under "Cemento"?
    Second question: is it possible to update the assigned custom PSET with the new order/new entries without deleting and reassigning it?
    The only way is to create a custom script?
    Thank you very much :)
  2. M
    Properties are a set data type, which means that it's unordered. I guess we should at least consistently show them alphabetically. Please feel free to file a bug report.
  3. V
    I have filed a Pull request that I believe can achieve that by sorting the properties when the add_prop_template is called.
    Update add_prop_template.py so the properties are sorted #6324
    It is very simple (just one line) but has the side effect that when you edit the property it is not reordered. Only when adding it.
    See example:
    Thanks!
