Bonsai Tutorial - Beginner Project - Part 1 - Modelling - 2025
  1. A
    https://youtu.be/Jc896Sob2bU
    Update of the Beginner project in Parts, everything is faster and easier
    Any comments put them here,
    I aim for these to be about 15min chunks,
  1. M
    This is incredible! Is there a reason it's marked as unlisted on YouTube?
  1. A
    It's public now, just a momentary mess up
  1. K
    i have seen that you dont make the ramp as solid. so is it okay in IFC validation, i mean is that valid object.
  1. K
    how can we load the ifc demo library on startup ?
  1. M
    @kalpit3d just select the demo library, instead of blank project, before create new project
  1. M
    @kalpit3d IFC does not have geometric requirements. It's valid to have an object with no geometry, or geometry that is an infinitely thin plane, or a solid that is a mesh, or a solid that is an extrusion, etc. The only thing to consider is whether or not that geometry is appropriate for your visualisation / documentation (e.g. if it's not solid, then in a section view you won't get the depth).
