D
by DavidE on 25 Mar 2025, edited 1 Apr 2025
Dear Community,
I need to to aquire specific property values of elements that are connected to a specific room via IfcRelSpaceBoundary.
Something like the accoustic rating of the walls and doors that surround a specific room. I would like to use Bonsai (IfcCSV) or IfcOpenShell python to do that.
I cant find something related to this in the Selector Synthax part of the IfcOpenShell documentation.
Any advice would be highly appreciated because I would like to avoid falling back on possible options to export this data from a proprietary authoring tool.
by steverugi on 25 Mar 2025
@DavidE
Dear Community,
Do you have virtual or physical elements delimiting spaces in your model?
According to buildingSMART page on IfcRelSpaceBoundary you have an inverse attribute in IfcSpace named "BoundedBy"
I can dig deeper tomorrow
D
by DavidE on 26 Mar 2025
I am only concerned with physical elements like walls etc.
with the Spreadsheet Import/export in Bonsai its possible to aquire the data of the IfcRelSpaceBoundary (RelatingSpace, RelatedBuildingElement), but I need to "ask" the IfcSpace about values of the surrounding Walls, Doors etc. OR the Doors/Walls about their values and the IfcSpace they are connected to.
The issue for me is that its not a direct connection from IfcSpace to IfcWall but because the IfcRelSpaceBoundary is the "middleman" I struggle to design a query.
by steverugi on 26 Mar 2025, edited 26 Mar 2025
@DavidE
can you share the model (or a reduced version of it) and the query used?
I am trying to replicate this in Bonsai but can't find the way
+4 votes
an example to find elements into an IfcSpace (a wall contained in a space) I'd use
to get
since the relation in this case is ContainsElements
you can also use the Inspector to find the "path"
D
by DavidE on 27 Mar 2025
Sorry for the delayed reply!
Attached is the model, which is just a two-minute test model from Archicad that contains the IfcSpaceBoundaries for the space to the walls that I used for testing.
I did not write a query yet, as I did not find suitable commands in the synthax. The screenshot is just a filter for all IfcSpaceBoundaries in the project and their connections.
by steverugi on 28 Mar 2025, edited 28 Mar 2025
Hi DavidE
with this query:
you can have this output:
is it OK?
the other way around, listing spaces and relevant entitites would have as many columns as the possible entities (1 to many)
listing elements is easier since most likely there is only one space per element (1 to 1)
+4 votes
To look for properties assigned to an element you can use this:
to return this:
D
by DavidE on 1 Apr 2025
Thanks a lot!
"ProvidesBoundaries.RelatingSpace.Name" is what i was looking for!
