Is there any possible way to re-imort ifc file with changes made in the file ... for example same as the lumion
Hi @Anas2563
you mean this?
I'm not sure if it works better now, but last time I checked you had to delete the . blend file Bonsai creates and links to be able to see changes.
@JanF
It used to be as you wrote but now it's working
Thanks to @Massimo :)
@steverugi Thank you but it doesn't work i don't know why .... i save the file with the same name and click reload and nothing happens
@Anas2563
You need latest release not stable one, that might be the reason?
i downloaded the latest version of blender ... or should i download another version
Sorry I meant latest of Bonsai (unstable)
Yeah i have the latest version
I am now installing B4.4 on this machine to check if that is the cause of the problem, in the meantime see my 4.3.2 with 250407 unstable installation
the one on the left is the original model linked in the one on the right
in case of complex models the sync may take a long time too
it works fine in 4.4.0 Bonsai 250410 too
thank you so much @steverugi
