This discussion was created from comments split from: <a href="/discussion/26/bonsai-new-release/">Bonsai new release!</a>.
not working for me
@sahrul Try and download these files and try to reverse engineer what's going on...
https://hub.openingdesign.com/OpeningDesign/Visualize_IfcMaterialLayerSets
Print SECTION - WEST - BUTTED ROOF_no_layers, and inspect with google chrome, or favorite browser.
To download all the files...
thanks @c4rlosdias @theoryshaw
A beautiful wall layer junction — how can it be achieved?
Play around with that value...
From standards...
https://ifc43-docs.standards.buildingsmart.org/IFC/RELEASE/IFC4x3/HTML/lexical/IfcMaterialLayer.htm
The relative priority of the layer, expressed as normalised integer range [0..100]. Controls how layers intersect in connections and corners of building elements: a layer from one element protrudes into (i.e. displaces) a layer from another element in a joint of these elements if the former element's layer has higher priority than the latter. The priority value for a material layer in an element has to be set and maintained by software applications in relation to the material layers in connected elements.
Wow..like Archicad
I've tried the ZIP file, but it doesn't work.
@sahrul are you receiving any error message? If so, can you please file a bug? Are you sure you have upgraded to the latest versions of both Blender and Bonsai? A video recording of what you're doing will also really help.
From standards...
I can't download that file
Yeah, just realized that it doesn't work either.
You can sync the repo, but it takes a little bit of know how..
If you're interested in knowing how, this tutorial could help:https://hub.openingdesign.com/OpeningDesign/OD_Library/src/branch/master/BIM/Workflow/OD%20Workflows.md#file-management-on-windows
Have been meaning to clean this tutorial up one of these days. :)
There's countless other resources on the web that explain how to sync a repo too.
