by brunopostle on 4 Mar 2020, edited 9 Sep 2023
+4 votes
I mentioned there is a vim syntax highlighting configuration in File::IFC, I'll attach it here. It helps make an IFC file a little bit easier to read:
View attachmentTo use it, download the file and rename it to ~/.vim/syntax/ifc.vim
Then edit your ~/.vimrc file and makes sure it says something like this somewhere:
syntax on
au BufRead,BufNewFile *.ifc set filetype=ifc
by Moult on 4 Mar 2020, edited 4 Mar 2020
Awesome work! For those on Vim who want a quick fix, another solution is :set syntax=stp. This sets the syntax highlighting to the STEP syntax.
This is what it looks like:
by brunopostle on 22 Jun 2020
+3 votes
In further attempts at making IFC files easier to read, I implemented a tool that builds a DAG for any IFC file and reorders the entities using a depth first sort. This places referenced entities before the entities where they are referenced, and generally puts entities that have lots of references (like IFCOWNERHISTORY) towards the front.
by Moult on 22 Jun 2020
@brunopostle very cool! Something to add to the wiki, perhaps?
Y
by yorik on 22 Jun 2020, edited 22 Jun 2020
I also made one for geany . It needs some more work, but here it is already...
You need to add this file to .config/geany/filedefs and after that inside geany, go to Tools->Configuration Files->filetype_extensions.conf and add a line like this: IFC=*.ifc
C
by Cyril on 22 Jul 2020, edited 22 Jul 2020
+4 votes
For vscode users there is now also a nice extension available : ifc-syntax
It also do syntax enlighting for express files :
by Moult on 22 Jul 2020
Should these (both geany and vscode syntax highlights) be added to the wiki? It looks cool!
R
by ReD_CoDE on 23 Jul 2020
@Moult If you mean markdown styles or similar things, I'm not sure about IFC, but other languages have styles, and some platforms implemented them, for instance, Discord:
https://gist.github.com/matthewzring/9f7bbfd102003963f9be7dbcf7d40e51
by Moult on 23 Jul 2020
Thanks @Cyril - I've also added the Notepad++ one from earlier.
@ReD_CoDE no worries, @Cyril has added the page :)
by bernd on 29 Jul 2020
I missed about these styles, awesome. Damn on Linux I use kwrite ... Nothing out there ?!?
by Martin156131 on 9 Sep 2022, edited 9 Sep 2022
+3 votes
I am a bit late to the party, however here is also my theme:
It's a solarized light theme for notepad++
The file is saved here
P
by petrisch on 14 Jun 2023
Hi Everyone
For my own convenience I wrapped the vim highlight in a plugin.
https://github.com/petrisch/vim-ifc
@brunopostle since you did the job actually, you can also fork it back and we can keep yours as the "official".
I wasn't shure about the commentstring. I have copied it over from rust, but I don't know if // is actually a comment in IFC?
Is there any indentation rules for IFC?
Anyway a tree-sitter or LSP Plugin would be the real deal, but thats a bt more effort :-)
by brunopostle on 14 Jun 2023
Great! IFC has comments like C that can span multiple lines:
/* this is
a comment */
There is no indentation, but sometimes there are spaces after the step id:
#101=IFCSOMETHING();
#102 = IFCSOMETHING();
#103 =IFCSOMETHING();
P
hm, I'm not shure if
setlocal comments=s0:/*!,m:\ ,ex:*/,s1:/*,mb:*,ex:*/,:///,://!,://
setlocal commentstring=//%s
Covers that correctly. It doesn't highlight correctly for me, but that could be a colorscheme issue.
On the other hand I have no idea what this regexy thing does :-)
About the indentation, I don't think we can cover that with vimscript.
Does that have a different meaning? I hope not.
This original syntax file was mashed together from other files, I suspect that the //%s entry isn't necessary.
W
by wmi on 15 Jun 2023
When I was trying to enter 'ifc syn' into the search field inside visual studio code I stumbled upon 'step syntax' some entries below 'ifc syntax' which seemed like Dion's vim quickfix at first, but it seems it also offers to follow the references and occurences of entities in the file.
by brunopostle on 15 Jun 2023
Following refs would be useful, the standard stp highlighting only has two colours here
P
by petrisch on 15 Jun 2023
Just committed a new version. Had to realise, that the comments were not defined in the syntax.
This should now highlight the comments correctly.
I therefore also changed the ifcGID to "Label". Don't know what it actually is called. Should probably search for a IFC format specification.
H
by hlg on 6 Jul 2023
Nice! I have this in my .vimrc:
set iskeyword+=#
autocmd CursorMoved * exe printf('match IncSearch /\V\<%s\>/', escape(expand('<cword>'), '/\'))
This highlights all occurrences of the word under the cursor while treating local IDs (starting with #) as words (not as two words - hashtag and number). You can also navigate the occurrences with * and #. Might be a useful addition to the highlighting.
H
by hlg on 9 Sep 2023
Has anyone created or seen an SPF highlighting definition in the KDE syntax definition format? Would be great to have it included in the KDE syntax repository. I guess these are used by many KDE tools like kwrite (@bernd) but also beyond, for example by Pandoc through the Haskell library skylighting. Just want to ask before carving out some time and getting my own hands dirty.
