@bernd Any reason the *.feature files are not stored in bimtester/features folder ? Would it be not good to have common test directly available to user rather than having to copy/paste from wiki ?
Are ther any on the wiki?
ATM some basic example feature files as well as some ifc are stored in examples ... https://github.com/IfcOpenShell/IfcOpenShell/tree/ebe5460a9f69ed8a39bfbe8937884ec99202000b/src/ifcbimtester/examples/01_ifcschema_translated
May be we could add more. Test to the example ones but the examples itself should be suitable for the feature files than. It is on my TODO for bimtester.
Saving the feature files in bimtester/examples seams fine for me. Any special reason why you wuold like to have them in a directory called features? This directory name is no longer needed to run BIMTester.
Yes all the MicroMVDs.
To follow behave advices/conventions so it is easier to find and understand the project structure ?
Thanks for the links.
The feature files from the wiki are templates, not ready to use feature files. If we put them into the repository we should put them in a template directory.
Putting the featrure files inside the code would make things more difficault for the user. The interface for the user is the feature file. If we put the feature file inside the code a standard user might be confused. IMHO we should keep the feature fils splitt from the code.
But the behave standard says it different ...
We need @Moult here ... Dion what is your opinion in this regard?
