D
by duncan on 24 Nov 2020, edited 28 Nov 2020
I've created a new page on the wiki https://wiki.osarch.org/index.php?title=OpenBIM_Manufacturer_Content
Anyone have comments or experience to add?
I have a small job creating content for a manufacturer and am looking for the best way to make the content available in a useful way to as many software platforms as possible. My authoring software is Revit as well as whatever free/libre tools we agree here are useful. For example I discussed with @Cyril and @Moult that maybe modeling the objects for IFC export from scratch in FreeCAD would give a better result than exporting them to IFC from Revit.
So, what do people think I should do? And please edit the wiki adding your knowledge.
by Moult on 24 Nov 2020
I've added a bit more to the table at the bottom, which hopefully can help people make an informed decision.
I
by infeeeee on 26 Nov 2020
I think it's useful to look what filetypes are supported on Bimobject.com. They are one of the biggest manufacturer content site. They support 69 different file formats, some of them are just containers like zip or non bim filetypes like hatch patterns or pdfs. Here is the list of their supported filetypes for reference:
3ds
Allplan
ARC Plus
ARCHICAD
ArchiCAD AAT file
ArchiWIZARD
ArchLine
Artlantis
AutoCAD
Autodesk Civil 3D
AutoDesk Inventor Assembly
AutoDesk Inventor Part
Bentley MicroStation
BIMx
Cinema 4D
COBie Product Data Sheet
COBie Product Data Template
Collada
DWF
DXF
Dynamo
Excel
fbx
Filmbox 3D Asset Exchange (FBX)
Hatch Patterns
HTML
IES
Ifc
Initial Graphics Exchange
Installation File (EXE)
itm
JPG
JSON
JT
Light Data
Log File
Materials & Textures
Microsoft Visio
MiniCAD
MLIB
OBJ
PDF
PLA (ArchiCAD Model)
PNG
Point Cloud
Powerpoint
Revit
Revit Family Type Catalog
Revit Installer
Revit Lookup Table
Revit Shared Parameters
Rhino
SAT
Sketchup
SolidWorks Assembly
SolidWorks Part
Step
STL
Tekla Structures Model
TurboCAD
Twinmotion
VDI 3805
Vectorworks
Video
WinRAR
Word
WRL
XML
Zip
J
by JanF on 26 Nov 2020
I would argue that dwg stores parametric capabilities to a certain extent, parametric blocks in dwg are quite powerful, or do you mean something else?
by stephen_l on 26 Nov 2020
You mean AEC Objects, with obscure "objects enablers" like ?
J
by JanF on 27 Nov 2020
Sorry, I don't really understand your question
by stephen_l on 27 Nov 2020, edited 27 Nov 2020
AEC Objects are parametric objects embed into .dwg, they require special software handlers and mostly are in use in domain specific applications like Architectural Desktop (discontinued), AutoCAD Architecture, or AutoCAD MEP. In order for other ADSK software to be able to read them, one must install dedicated "object enabler".
J
by JanF on 27 Nov 2020, edited 27 Nov 2020
Nah, I simply meant the parametric blocks you can build in the block manager and if I remember correctly Autocad architecture has a library of those. Thay can have attributes and parameters.
(Not that anyone in their right mind would ever try to seriously do that and hilariously it seems to be more or less limited to xy plane)
D
by duncan on 28 Nov 2020
Anyone know how to make reference notes in the wiki? It'd be fine to mention parametric blocks, just not in the main text.
by Moult on 28 Nov 2020
@duncan use <ref>foo bar</ref>
