Translation of bimtester from IfcOpenShell
  1. B
    Dion has done some changes lately I have not yet tested. But before it was very easy if you are on a linux machine ...
    • see https://github.com/IfcOpenShell/IfcOpenShell/tree/5f8e77c29281ffd778ee530051fbe45b68eae19d/src/ifcbimtester
    • clone ifopenshell
    • install dependencies: behave (at least 1.2.6) and pystache, ahh and for sure Python3 and PySide2
    • switch into directory src/ifcbimtester and start bimtester gui by the use of parameter -g but this seams to has changed
    • in the gui one just need to set a directory. all feature files in the directory are used by the BIMTester run and a report is created for each feature file
    • neither BlenderBIM nor FreeCAD are really needed to run BIMTester
    but as said this was befor dijon has changed some stuff ...
  2. B
  3. L
    @Bernd.. Dijon a sa moutarde; l'Australie et nous avons Dion. :-)
  4. M
  5. T
  6. M
  7. T
  8. S
    Very effective work, I plan to translate it into Chinese in the next few months. Maybe I will need your help then.
  9. D
    Fantastic!
  10. B
  11. L
    language: fr
    Fonctionnalité: Base setup ( Configuration primaire )
    In order to view the BIM data ( pour permettre la visualisation des données BIM )
    As any interested stakeholder ( ainsi que quelque Participant intéressé ) or ( comme tout participant intéressé )
    We need an IFC file ( ceci requiert un fichier IFC )
    Scénario: Recevoir e fichier
    • Les données IFC doivent utiliser le schéma "IFC2X3"
    Scénario: Project information ( Informations concernant le projet )
    • The project name, code, or short identifier must be "BIMTester Example 1 - IFC2X3" ( Nom du projet, son code ou un identifiant sommaire du type "BIMTester1-IFC2x3" )
  12. B
  13. G
    You can ping me too if you need french translations ;)
  14. B
    great. I might come back later on in this regard ... ATM only the very basic is translated.
  1. Page 1
  2. 2
  3. 3
