@JanF did someone remove the bit a few minutes in where we talked about sound issues?
Right, I forgot about that and edited only the beginning and the end. Will fix it.
I hope that doesn't change the URL ... if it does then maybe don't worry about it.
I cut it directly on YouTube, so everything stays. It should be fixed now.
Hey these are pretty god numbers I think (sorry about the danish but you get the point). Good work.
@JanF can that version you cut be downloaded and added to Jesusbills folder so he has the same version?
I find it interesting that they scored like this, usually it's exactly the opposite, as the number of subscribers grows, newest videos get the most attention.
Sure it can be, but I don't quite understand what for? I haven't uploaded any editted recordings to the folder, right now it only contains the originals. ( I can do that of course) or do you mean some other folder?
@JanF it's because I really would like us to use peertube as soon as we have something set up.
It would be nice to have a central OSArch cloud to store all this stuff.
@JanF @gokermu @condur anyone know how to feature the Connect Playlist on our page? I've already subscribed to it but it isn't appearing:
I've added the playlist to our "saved playlists". Is that what you mean? Or we can make a playlist and add all the speckle videos - then it would appear in the upper group.
@JanF that's exactly what I was trying to do. Thanks!
We need to promote our Youtube channel more. We have only 500 subs.
Promote on Twitter: https://twitter.com/OSArchOrg/status/1464901266153295872
Promote on LinkedIn: https://www.linkedin.com/feed/update/urn:li:activity:6870669003329728512
